Question about Whirlpool Dishwashers
Whirlpool quiet partner II dishwasher is leaving chunky residue on dishes
My dishwasher had been cleaning brilliantly for years (four-ish years). Quite suddenly my clean cups had dried on food inside. Sad! I've tried the vinegar trick and a couple of other layman clean-out-the-machine solutions. It is still happening.
  • Anonymous Mar 31, 2014
    I need to clean the food trap in the right rear corner of the inside of my dishwasher. Can I remove the trap to clean it?
    I need to clean the food trap located in the right rear corner of the inside of my Whirlpool 280-0 dishwasher. Can I remove this trap?
I H AWHIRLPOOL DASHWASHER MODEL # DUII45XTPB6 quite partner ll I lost my manual , Im trying to acess the error codes . or Im trying to get the diagnostic codes to start . Hope some one can Help""""""
Posted on Nov 14, 2008
Whirlpool dishwasher doesn't make the regular sound
The problem could be a clogged water line or intake valve. Check the lines and make certain they are open and flowing.
Feb 26, 2014 | Dryers
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
MAKE SURE THE UPPER WASHER ARM IS NOT CLOGGED, SOMETIMES FROM DETERGENT BUILD UP IF YOU'RE USING POWDER DETERGENT. CHECK ALSO FROM THE BOTTOM IS THERE'S ANY DEBRIS THAT MAY PREVENT THE WATER GETTING TO THE UPPER WASHER ARM
Jan 16, 2010 | Whirlpool Dishwashers
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Where is the food trap located in my dishwasher? I am having problems with residue being left on my dishes. Dishwasher is 3 yrs old. Whirlpool Quiet Partner II.
They are usually located on the bottom of the dishwasher on the inside, towards the back. Some of them require you to unscrew the screws to access it. It will look like a small grid, and under that is where it gets nasty. Hope this helps.
Dec 27, 2009 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirlpool dishwasher QUIET PARTNER II doesn't clean dishes, leaves film
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 15, 2009 | Dishwashers
My whirlpool gold quiet II doesn't clean well. leaves residual stuff on dishes. Is there a filter I do not know about That I should clean?
no there is no filter to clean or change,have you put drying agent in your unit? like jet dry or somrthing like that? try some this might help.
Aug 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
786 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Bruce Denton
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
