Siemens SpeedStream Modem (4100) (SS4100) Logo
Posted on Oct 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Speedstream 4100 does not work with router
I have AT&T dsl using a speedstream 4100 modem with my windows XP toshiba alptop computer. The dsl connetion works fine but when I try to put in the netgearWGT624 modem inline the connection won't work. I was tiold the password stuff is located in the speedstream modem. How do I get the router to work with this speedstream 4100 using At&T dsl?
Jim Miller
[email protected]
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Oct 20, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746964
Points
3939
You can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Speedstream 4100 cant connect
plug the computer into the modem testing dhcp
if it gets internet the modem is the dhcp server
the plug into router by itself disconnected it from modem testing dhcp if gets ip address and no internet it's the dhcp server
dhcp can be done by the modem or router. I bridged mode the modem and let the router do dhcp. of course the router must be pppoe for dsl. been years since I had DSL, hope it helps
I can't get my Siemens SpeedStream 4100 to work with my new AT&T DSL service. I used to have DSL through a local company, Humboldt Internet, but they stopped offering DSL and sold off their DSL...
When you are connecting to it, are you using the lan connection straight into the device? When you do that is it showing as at least connected to the device on the computer? You did not post the operating system but can you check the router address by using the command prompt and using tracert commands to see what it is listed as? If you are using windows 10 have you use the powershell command to reset the winsock? Did you use the 30 30 30 reset method on the device?
4helpful
2answers
I have a Speedstream 4100. When turning on the modem, it goes through the initial tests (lights,etc.), then the only lights that come on are the power light and the DSL light (steady green). The ethernet...
Your computer is not communicating with the router and modem it needs to reset to factory specs then reboot the computer,modem then router in that order.If this does not work contact your dsl provider for info as to your ip address ,gateway and reset with the provider.
Speedstream 4100 started flashing red or green
The problem is probably not your modem. The dsl or cable service is possibly out. DId you call your service rep for help? I would start there.
Will there be a problem adding Siemens speedstream 4100 to DSL?
u need to setup ur router to program it so ocnsequently u can connect ur pc to the router instead to the modem
1) so u need to prgram ur router by configure the required settings
2) u need to write down ur username and password inside router program
3) then u can be connected to the internet via router
good luck
Problems connecting Siemens Speedstream 4100 to a non-AT&T ISP
The answer is Yes,speedstream 4100 cannot be used in bridged conditions for any other isp
Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
SS4100 DSL Modem continues to waken my Win XP Harddrive from sleep
Yes Lee, i had also solved the problem before by unchecking the option in driver properties.
Top Siemens Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
