Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
Todd Adkins Posted on Jan 28, 2012
Temp keeps rising and won't shut off
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 • Pool & Spa
1helpful
I have a montgomery wards furnace model srm54013a. won't shut off, keeps putting out heat
SOUNDS LIKE A BAD THERMOSTAT OR THE RED & WHITE WIRES IN BACK OF STAT ARE TOUCHING ONE ANOTHER COMPLETING THE CALL FOR HEAT.
Cooling system problem for Pontiac Grand Am GT 1999, Starts overheating when sitting still but starting the A/C helps cool it.
If it has an electric radiator fan (not AC fan) The radiator fan is not working. Possible coolant sensor or switch.
My kobalt air compressor model#215914 won't stop running is it suppose's do that?
All compressors run up to their rated high pressure level, usually listed on the data plate on the compressor or in the manual, then the pressure regulator turns them off. If your compressor is not shutting off it is either not getting to the pressure it takes to get the pressure regulator to turn it off or the pressure regulator is broke and won't turn the motor off. To check which, turn the compressor on and watch the guage that shows tank pressure. If the pressure rises then stops at a level below the rated pressure for your compressor and the motor continues to run, you have a leak somewhere. It could be the tank drain valve, the lines from the pump to the tank, the valve plate or in the piston cylinder area. If the pressure rises more than ten psi above the rating for your tank, your pressure regulator is broke or possibly set too high. If you know how, you can try lowering the shutoff point to see if that fixes it but you're usually better off replacing the regulator.
My air conditioner won't cool down
I Think when it goes back to 33 thats your ambient temp . the temp in the room thats its trying to get down to .
If you set it on 22 . and just ignore the 33 it does it stay on cooling ?
My 1995 Plymouth Neon will run fine as long as it's cool. But as soon as the temp outside comes up, it shuts off & will restart within a few minutes. If you do this very many times,, it just...
if car shuts off when hot outside, change thermostat and radiator pressure cap.-- heres more-car shuts off when tempurature of engine gets to normal. causes; low coolant, failing coolant temp. sensor, air in water pump. it takes 10-15 minutes to reach normal range. hope this helps! good-day!
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
2helpful
4answers
Fan keeps running after engine is turned off
why does the cooling fan start working as soon as i start the car and doesn't shut off until i turn off the car?
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
ZJ Limited
ZJ Limited
john h
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
