Bosch wfd 2473 washing machine it will not pump or spin
This video will show you how to change the pump washing
machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: Bosch washing machine not getting hot
one of 2 things, eather the element is faulty or the electronic control board wich puts power to the element is faulty.
more likely to be the element
SOURCE: WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
SOURCE: Bosch WFD 2473 - wont spin. I've taken out the
Even if the pump is not working, then so long as there is no water in the washer, it should spin
If it does not, then I would suspect the motor brushes are worn out.
You need to remove the motor to check the brushes, if they are less than 2 or 3 mm long then they need replacing.
I do not think the washer you found is off the pump,more likely out of someones pocket.
Hope this helps with your problem.
Testimonial: "Thanks - will try that now! "
