Has color when you play a dvd but no color on cable TV, Help
The problem is on the cables , look on the back of the cable box , if it is hd box the on ly thing you need to do is put the cables base on there colors green with green , red and blue , the other 2 are for video , but if it is normal box just put the yellow color with yelow on your box to your tv and the other to are audio
SOURCE: help hooking up tv to surround sound system with dvd player
with my Ws-65513 I run only right and left channel down to the aux from there your dolby 5.1 should doe the rest .most systems have center (speech) (R.front) (Lfront)(R.rear)(L,rear) and SW .center you want on the bottom or the top of your screen ,The SW you want Ever behind your set or under your couch.LEFT AND RIGHT REAR YOU WANT SOME WHERE BEHIND YOU OR AT LEAST 90% TO WHERE YOUR SITTING NOW THE FURTHER YOU SET THE REARS BEHIND YOU THE MORE DELAY YOU SHOULD HAVE ,THERE IS AND ADJUSTMENT SOME WHERE BETWEEN 10-30 MIL-A-SECONDS THIS GIVES A SLIGHT ECHO FROM FRONT TO BACK..
i HAVE AN AIWA AMP RUNNING A 12INCH FISHER,CABINET BOSE,AND A PANASONIC SUROUND AS MY FRONT, LEFT AND RIGHT STACKS.WITH A JBL CABNET AND PANA CENTER FOR SPEACH .THEN LET THE REAR GET BOOSTED WITH THE PANA SUROUND SYSTEM BECUASE i NEEDED AT LEAST ANOTHER 120 WATTS TO RUN THE THE JBL12,WITH A PANA SUROUND AND A SUPER TWEET WITH A I/2 POUND MAGNET AS MY L AND R REAR,
THE ***** IS WHEN IM RUNNING MY LOWLY 44 DOLLOR PHILLPS WITH A SEMI 10801 ,I CANT GET MITS SPEAKERS ON LINE,THERE IS ONLY ONE INPUT.wHAT YOU REALY WANT TO DO IS HAVE NO DELAY ON THE CENTER,THEN 5MIL TO YOUR MIT SET SPEAKERS.YOU WILL GET AUTOMATICLY IF YOU SET THE TV ON SURROUND,PUT ONLY KEEP AT 1/4 VOLUME OR YOU WILL SCREW UP THE WHOLE EFFECT HAS THE JUICE GOES TO YOUR LEFT AND RIGHT FRONT IT NATRUALLY HAS ANOTHER 3-5 DELAY AND SET YOUR REARS TO A LEAST 20 TO 30 MILL DELAY.iT WILL PUT YOUR LOCAL THEATER TO SHAME.
Warning make sure all your wires are in phase +to possative -to neg not only you get a ping pong effect if you plan push a lot of watts a surge could make you have a very bad day ,most wires are eather colored on the outside or silver or gold on the inside.if you plan on moveing one side away from the compared to the other side its better to increase at the gauge of the wire,or you will never get the balance right and end up throwing your equipment at whatever pissed you off in th first place.
it,s a type of balance of chi ONCE YOU HAVE IT RIGHT,ANY ONE OR THING THAT ENTERS YOUR SPACE WILL NOT BOTHER YOU AS LONG AS TUBES CONVERGE AND SOUND IS
TUNED LIKE A FORK AND IF SOMEONE ***** WITH YOUR SYSTEM THE TUBE IS SO BIG
YOU CAN AT LEAST FIT ONE BODY IN IT ,i THINK THE CASTORS CAN AT LEAST STROLL YOUR PROBLEM TO THE LOCAL LAND FILL.
i KIDDING PUT i LOVE MY SET ,.i WOULD LIKE TO KNOW IF THE NEW BLUE RAY WOULD CLEAN UP THE 1080i ANY BETTER. GOOD LUCK
SOURCE: HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
SOURCE: Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
SOURCE: mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
SOURCE: Mitsubishi 65413 loses convergence calibration
That model Mitsu doesn't accept 1080p input or 720 p input.You would need to chnge the output resolution on your bd player to correct this.
Was working great then all of a sudden the color was gone and the picture was there but in black and white.
