With my Designer SE I am using stitch #9 from the "F-1" applique stitches menu. It starts off ok, then about the third cycle the satin stitches bunch up and the "x" stitches back up into the previous satin stitches. Have tried loosening the tension with no success. I'd appreciate anyone's help! Thank you, Buffy
SOURCE: Satin Stitch Problems - Designer SE (similar to the Designer 1)
You should take your machine to a Husqvarna authorized repairman. Suggest checking the grounding of the tension unit stepper motor. Earliest models weren't properly grounded and tension could vary. An authorized repairman should know where to go from there. I don't know of anything that you should attempt on your own.
SOURCE: Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
I've already done what was suggested
it's possible that a cam could be damaged or it's out of time & needs to be serviced at a sewing machine repair shop
