Unable to connect Wirelessley to the Internet. This has happennd before and sadly, the previous solution has not worked (Simply turning the Firewall off). The OS seems to ahve simply forgotten that it is wireless capable, there are no options to connect to my Router and the sstem keeps on Insisting I attatch Hardware that was not needed before. I have tried to set up new networks and join other networks, but so far nothing has worked. Any ideas?
SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
SOURCE: I have a Thomson TG585v7 DSL wireless router. It
Check if there is any ip address added to the ethernet card of your laptop. And also check if you have enabled encyrption. If you are using DHCP then you better enable DHCP on router also..
SOURCE: My belkin54g router is currently hooked up to the
Change the router! or go to Belkin : Support : Setup Assistant for Routers
SOURCE: Weird problem. I have
You will need to contact Comcast. They will reset your service for the new equipment. Things are rarely "plug & play" with Comcast.
