Hotpoint RGB745 Gas Kitchen Range Logo
Posted on Oct 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TIMER IS BUZZING NON STOP.
WE HAD A POWER OUTAGE, AFTER POWER WAS RESTORED THE TIMER ON THE STOVE WAS BUZZING AND WILL NOT STOP UNLESS IT IS UNPLUGGED, WHEN PLUGGED BACK IN IT BUZZES NON STOP. WHAT CAN BE CAUSING THIS PROBLEM?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 324 Answers
  • Posted on Nov 04, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
324
Questions
Helped
120890
Points
632
How old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
1helpful
Every time I have a power failure, the timer stops working and I have to reset all the programs. I thought there is a battery built in to protect the programs during power failure. Why it is not working in...
Timer is not identified.
Copy following link to help identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Most modern digital timers have programming back-up that lasts indefinitely in memory until timer is reset.
However current time is sometimes lost with low battery or power outage.
In some timers there is rechargeable battery that protects all settings. This battery is non-replaceable, and can last a few years or more-less.
Since the market is changing rapidly, who knows what remarkable innovation will lessen quality, causing shorter lifespan of product.
Most timers have limited 1 year warranty against defects in workmanship.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Will not turn on, no display. only comes on when the reset button is depressed and held.
1) More information is needed.
Is this new installation? Or timer that worked before and stopped working? Add a comment with complete information.
2) There are no repairs for defect timer, other than to reset timer and reprogram.
If functionality is not restored, then timer might have gone bad.
3) Question posted under ET724 in-wall timer.
If you have different timer, then add a comment.
There are at least 2 different versions of this timer. Grasslin, and GE and now Intermatic, and maybe others have made -or- are making this timer -or- have sold rights for somebody to make this timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei500
http://waterheatertimer.org/pdf/et724-timer-instructions.pdf
4) The screen blanks during power failure.
Check that timer is getting power, and breaker is not tripped.
Frequently, power outages cause timers to fail when power turns on again and power surge affects timer.
5) Known versions of this timer are connected to Neutral wire. Timer has internal, non-replaceable battery that can go bad.
If timer-white wire is not connected to neutrals, then display will not operate.
Neutral wires are white wires that are twisted together, covered with wire nut and pushed to back of box.
6) Add a comment for more help
7) Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
3helpful
2answers
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
My intermatic ej351c timer is not working properly. lights only stay on a few seconds - a few minutes before shutting off, even when button is pushed to override program. is there a battery that needs to...
Timer has non-replaceable capacitor battery for 15 minute carryover during power outage.
Timer can be affected by radio and TV receivers. Unplug those devices and check if function is restored.
Reset timer and program again.
If timer function is not restored after reset, then buy new timer.
Timer has 1-year limited warranty, and is rated for incandescent only, up to 150Watts.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
2answers
I have a Tappan gas stove. Don't know how old the stove is as the stove was in the home when I purchased it. Six years ago we had a power outage. When the power was restored the clock started beeping. Only...
Try disconnecting the AC to your range and leaving it overnight. If this doesn't help, the clock has probably been damaged by a power surge during one of the dropouts.
3helpful
2answers
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Top Hotpoint Kitchen Ranges Experts
vince
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
