HOW TO CHANGE A SERPENTINE BELT
SOURCE: 1994 case 580 sk backhoe
Now that you smoked the transmission, it does not matter what caused it. You now have to rebuilt the transmission, and it will cost to replace and clean parts contaminated by letting it slip so much.
Don't know if the transmission problem was caused by the brake seal installation or not, but probably not. There was probably simply a transmission leak as well, and if you had kept the fluid up, it may have been able to function for a long time.
But after a transmission starts to slip, do NOT use it. At all.
There is no such thing as a little slip.
Now that it has been cooked, you would be better off with a rebuilt exchange instead of trying to rebuild what is left of the old one.
SOURCE: case 580 super e.
You are having the typical shuttle failure. There is a bellville type spring that returns the clutches when pressure is taken from the clutch pack. That spring will fail with time, it is nothing you did.
