Drawer jammed when CD was loading into CDR20 on A side when making a recording. Likely CD was not seated flat in drawer. After removal of CD the drawer was manually pressed shut. Next time open drawer button was pushed display toggled back and forth between open and shut and then ERROR message came on. Drawer does not open up automatically at this point. After pressing open drawer button ERROR message comes on and drawer remains closed.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
I am on my 3rd harman-kardon CDR2 unit- and always the same problem arises; one of the cd doors eventually jam rendering the unit useless for me. I prefer stand alone units and HK reproduces well (sound quality-wise) but this damn flaw is so upsetting. Also stand alone cdrs are harder to find as they are being phased out of the industry. Any suggestions on how to fix tray-jams?\
