My computer can't find internet at all. I have clicked on the button ontop to enable the internet and it can't find any internet at all. I have another laptop that has no problem finding internet and there are about 8 others that pop up form the apartment we live in. However, my MSI wont even find one..
SOURCE: can't find the wireless antenna on my msi u100 series laptop
Not really sure what you are expecting. The wireless antenna is within the computer--you won't see it.
What you will need to do is to turn the wireless networking on. This is done in some computers with a small switch on the case (in this case, there is usually a light that comes on when you turn the switch on). In other cases, you will have to use the Fn key plus one of the special function keys at the top of the unit (has a picture representing a wireless connection on it--possibly something like an antenna).
If this fails, go into your network connections and see if the wireless connection is actually turned on. If you have Vista, this is sorta easy as you click on "connect to" and then choose "wireless network"
SOURCE: cannot connect to wireless internet
make sure you can detect networks
If by mistake you disabled the wireless, you can re-activate it by pressing fn-f11
Good luck
SOURCE: My wireless connection works on all the other
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
SOURCE: msi notebook can't get it set up to the wireless
I am having the same problem and am unable to connect my sons msi wind u100 to a wireless router
hope someone can help us
SOURCE: I have a mSI laptop computer with an inbuilt
camera driver is installed ? if yes find in control panel
Open Internet Explorer by clicking the Start button , and then clicking Internet Explorer.
Click the Tools button, and then click Manage Add-ons.
Under Show, click All add-ons.
Click the add-on you want to enable, and then click Enable.
Repeat step 4 for every add-on you want to enable. When you are finished, click Close.
Click the Tools button, point to Manage Add-ons, and then click Enable or Disable Add-ons.
In the Show list, click Add-ons that have been used by Internet Explorer to display all add-ons.
Repeat step 4 for every add-on you want to enable. When you are finished, click OK.
Click the add-on you want to disable, and then click Disable.
Repeat step 4 for every add-on you want to disable. When you are finished, click Close.
Repeat step 4 for every add-on you want to disable. When you are finished, click OK.
Follow the steps below to run Internet Explorer
with all add-ons temporarily disabled. Add-ons will be disabled only
until you restart Internet Explorer normally. To disable add-ons
permanently, follow the steps in the section above.
To temporarily disable all add-ons
Click the Start button , click All Programs, click Accessories, click System Tools, and then click Internet Explorer (No Add-ons).
problem still is there!!
