Have sound but no picture. I have narrowed it down to the main board or inverter. Keep reading that I may have to replace the backlight "inverters". After taking the back of my tv off i only see three visible boards - the main board, the power supply and an inverter board to the right. I dont see or find dual inverter boards as I have read about. Is the "one" inverter board i see the actual back light inverter itself? If not, where do i find these backlight inverter boards? Thanks
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
SOURCE: need inverter board for vizio L32 model an idea on
You can get a replacement inverter board at this link below:
http://www.shopjimmy.com/catalogsearch/result/?q=vizio+L32+inverter
Just make sure you match up the part number on the board.
SOURCE: Bad backlight inverter on 42" RCA LCD
Does the backllght go out after a few seconds? Could still be a lamp or something else on the inverter boards. You could try used inverter boards from the same set with other problems (broken screen), Or a complete working backlight from another set but very delicate operation to swap the LCD display from one panel to another.
SOURCE: How difficult is it to replace backlight inverter on a LCD TV?
Replacing LCD inverter board is very easy.Does not involved in any soldering.It a long board in shape.Just take ur tv aparts,use a Philip screw driver take out 6 Philip screws each board and connections.Do the reverse to install the LCD inverter boards.Tries Websites like Shopjimmy.com,Ebay.com to buy refurbish LCD inverter boards.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
