My canon mx366 got error waste tank is almost full... i try this solution 1.turn on the printer canon mx366 2. press menu 3 press scan 4. press copy 5. press scan its not effective ,,,I can not enter the sevice mode,, the printer lcd just show up "save to pc" can anyone pls help how to reset the canon mx366 printer waste tank is almost full... I need to enter the service mode to access this procedure: USE > to got to NVRAM ACCESS Set ABS-M LEVEL to 0 Set ABS-P LEVEL to 0 Press STOP to EXIT
SOURCE: My pixma mx300 shows 5100 error message, and I
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
