Question about Alpine MRD-M1005 Car Audio Amplifier
Can I fix a fried amp?
I was hooking up a compaciter and didnt realize the compaciter had a charge stored in it. When tring to hook up to my amp, it touched the chassis of my amp and the amp has ceased to work. Checked all four external fuses hoping it just blew one of them, but they are all fine. Is there anyway I can fix it inexpensively because I have no warranty on the amp.
  • andrew1009 Apr 20, 2008
    I have an explode amp that recently stopped giving any output,i was not using a fuse from the battery but the fuses on the outside of the amp are still intact and the power light still turns on,is there any way the amp could blow without the fuses blowing?
  • Anonymous Mar 22, 2014
    the amp hooked up backwards and blew two of four fuses now wont turn on
  • 4 Answers
Hi, how good are you with electronics? Are you able to open up the amp and see any obvious problems? I suggest that if your not very good with electronic circuits, get a professional to have a look at it, as if you damage it more by trying to fix it your self, it will probably cost you more to fix it. It may be as simple as an earth track been burnt, but even that in most cases will force you to completely disassemble the amp to find the problem. It may also be the diode right next to the power supply terminals that may be damaged and in some cases that can cause problems. Let me know if you open the amp, if possible post some pics and will see if there is something obvious that stands out. Cheers
Posted on Jun 06, 2006
Many amps have a zenor diode in them that will protect the amp in the event of a short this diode is cheap and easy to replace. take the amp apart and look between the positive and neg rails on the board it will be there any one that sells them can test them if yiur multimeter does not have a diode check feature.
Posted on Sep 26, 2007
Wrong ohms and blew up the amp can it be fix
Posted on Mar 20, 2007
Transistors on the driver board have burnt out and i need to replace them but i do not know the part numbers POWER ACOUSTIC A3000DB MONOBLOCK AMP
Posted on Jan 10, 2007
    New Friend:
  • 4 Answers
The first thing you did wrong was buy a sony explode...those guys need to stick to making televisions, secondly ALWAYS have a fuse no more than 3 feet from your battery,between that and the one(s) on your amp it would be impossible to damage your amp.Also ALWAYS disconnect the neggative cable from your battery when you do any tinkering with the wires on your amp.
Posted on Apr 15, 2010
4 Suggested Answers
6ya staff
SOURCE:
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Amp not working
my friend your amp could be getting power that does not mean that it is working.the power only goes to certain point but because your regulator or other related component is defected your amp power supply will not work until the defect is corrected.take it to a tech and have your set repaired.good luck.
Posted on Jun 11, 2007
Anonymous
  • 12 Answers
SOURCE: amp light is on but doesn't put anything out to my subs
if you are sure its the amp. the problem is internal. but if your not sure, try a different stereo or source of sound to the inputs of the amp. if there is still no sound than it is the amplifier and it could be a number of things.
Posted on Jan 07, 2008
Anonymous
  • 19 Answers
SOURCE: i have 4/3/2 ch. alpine f-240 amp- i want to hook
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Posted on Dec 27, 2009
Hooked up battery backwards on my 1992 ford explorer. Got it running now the alternator isn't charging the battery. Has 12 volts power. Could it be the points on alternator where the wiring hooks into...
The battery needs 12.6 volts or more to be in service
When the engine is running you need 14 volts or more
out of the alternator to charge the battery
You can test the alt by testing across the battery term
or the alt output wire & ground to case or motor
Could be the diodes got fried & you need a new alt
Have it tested at parts store, if you can't figure it out
Check all fuses & fusible links first
Jul 26, 2013 | Cars & Trucks
I hooked my battery up backwards now the ignition won't turn over when I turn the key. It also sounds like its not getting fuel
hooking up backwards basically fries everything first take the starter and get it tested you problly fried the solenoid but pray you didnt fried your igniton switch on the car and as for the fuel you most likley poped the fuse pray that it is the fuel beacuse a new fuel pump can cost ya a good amount
Jul 20, 2013 | Cars & Trucks
Samsung corby not charging GT s3850
Are you very sure it is the right charger? I have hooked my phone up to charge before, not realizing that the charger I had used was for something else. Many of the chargers these days look very similar, sometimes exactly the same. However the output on the other charger is quite often not right. This will cause your phone to not be charged.
Sep 08, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
On 3rd alternator ,cant get them to charge the battery and in turn they keep burning out
First have battery checked at shop that knows what they are doing.
Aug 07, 2017 | 1995 Dodge Neon
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
http://www.ehow.com/how_7203337_charge-capacitor-car-stereo-system.html
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
Hooking up the amp i had the ground wire connected and was going to hook up the power wire and it hit the case of the amp know the amp turns on but there is no sound from the speakers other amps work on...
sadly, your amps' output MOSFETS are more than likely toast.
your amp was grounded, and you touched the amp chassis with the power line.
electricity will follow any path available to find ground. in your case, the output mosfets became your main ground-path since they are directly connected to the amps chassis (heat sink) and internally you had grounded the amp so power would flow full force through the output transistors in the serach for a ground.
open up your amp and smell the row of MOSFET transistors. you'll probably even be able to see some burnt transistor legs.
repair or replace.
May 08, 2011 | Kenwood KAC-7202 Car Audio Amplifier
How do we hook up speakers to our lg 42 inch tv, at the store we didnt realize it only had speakers in the back of the tv which hinders the sound?
depending on your model look in the back or side for (ext speakers) audio jacks out...this is where plug your ext speakers...if you are plan on using a 5 to 1 stereo receiver the speakers will be plug into the rec...
Jun 06, 2010 | LG 42LC2D 42 in. LCD HDTV
Shuts off when the volume gets turned up didnt do this wen new
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
Apr 06, 2010 | Kenwood KDC-BT838U Car CD Player
Alpine MRD-M1005 Car Audio Amplifier Logo
4,583 people viewed this question
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
