Hi, my oven door does not close... i am able to take off the door, but i do not know how to access inside the latch where the door hinge would attach... i think i may be missing a spring or a hinge may be broken...
can you help...
thanks...
the lower oven door on my jenn-air double oven does not close completely causing the light to stay on and the annoying buzzer to soundthe lower oven door on my jenn-air double oven does not close completely causing the light to stay on and the annoying buzzer to sound
AnonymousJan 01, 2009
Both lower and upper oven doors of my Jenn-Air double wall oven (JJW9827DDS) will not close all of the way. Heat escapes while cooking and the light stays on all of the time. When you push it closed tight, it just springs back open. I have had the hinge springs replaced twice on this unit. It works for a while, then the problem returns. How can I fix this problem permenantly?Both lower and upper oven doors of my Jenn-Air double wall oven (JJW9827DDS) will not close all of the way. Heat escapes while cooking and the light stays on all of the time. When you push it closed tight, it just springs back open. I have had the hinge springs replaced twice on this unit. It works for a while, then the problem returns. How can I fix this problem permenantly?
AnonymousMar 20, 2014
bd31 oven door hinge moun dropped inside casing. how do i retrieve it?bd31 oven door hinge moun dropped inside casing. how do i retrieve it?
AnonymousMar 25, 2014
Door won't close properlyDoor won't close properly
You can't post conmments that contain an email address.
Hi Elspeth:
Don't know what make or model you are dealing with, but from personal experience, here's what I dealt with.
- Oven door is mounted on spring loaded hinges. That's what keeps it in the closed position.
- To remove the door, it has to be fully opened, then lifted from close to the hinges, and slid out.
- To put the door back on, the hinges have to be in the "door open" position. Since they are spring loaded this can be tricky getting them into position.
- It's easier with a helper, one on each side....... slide the hinge legs into the slots. You'll need to lift the door slightly towards the closed position to allow the hinge legs to engage in the secure or latched position.
Hope this helps.
Cheers.
Hi Jorgey,
Either there's something inside that's stopping it closing properly or the hinges have been deformed and are not working correctly. So clear out the oven and try door. Otherwise inspect hinges carefully for deformation. If necessary remove door and hinges. Carefully try to reshape the hinges. If this fails you need new hinges
use a fulcrum in both hinges (dowel across the oven) to gently bend the thing back in to shape. not a lasting solution, but should be god for a few years.
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
I am afraid that the door hinges are non adjustable, and the only solution is to replace them as a pair.
There should be some kind of latch mechanism at the end of the hinge
where it is fastened to the door to compress the hinge to enable you to remove them.
Hope this helps.
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from www.kjmagnetics.com I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top. Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new. Hope this helps.
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
