SOURCE: Unknown files and impossible to delete
First turn on the palyer and change the usb mode to MSC and when you connect it the the computer it should show up as a flashdrive type thing. right click on ita and select format make sure the when you format it it is going to be formatted to FAT32 type it will delete every thing on the player including those files you said couldnt be deleted
SOURCE: unreadable files for Sansa e250
Don't worry, there's a solution.
You have to run what's called "Check Disk."
WARNING: Sometimes it will make files "disappear", but still use space. In that case you will have to format it and put the music back on. It all depends on how "corrupted" the files were. If your files disappear, reply stating so and I will help you out with that if you don't know how to format.
Thank you and please respond with any comments or more questions.
-John-
SOURCE: I want to delete some
Please give me a response on how to solve deleting from MP3 sansa m200 series.
I downloaded a cd to my sansa now how do I go about deleting from the player.
I'm on window media player 10 Thanks.
SOURCE: Accidentally deleted ALL the preset files in the sansa express
Head for computer restore back a few days ..
SOURCE: how do you delete files on a preloaded sansa
Go into the main menu, go to settings, go to format, and select internal and it will format the device, removing all songs from it.
