Needle you are using too thin for weight of fabric. Sewing machine needles come in sizes - you may be using a ballpoint needle to sew a heavy woven.
Another possibility here is that your needle may have slipped down. Check it by loosening needle bar clamp. HOLD needle so it doesn't fall down "hole" then make sure it is pushed all the way up before tightening the needle clamp screw.
Make sure you have attached the correct presser foot for the stitch pattern you want to use, then check to see that presser foot sits securely.
Do NOT pull fabric while sewing! This will bend needle. The feed dogs move the fabric for you so your job is to GUIDE the fabric, not pull or push it. Some sewers don't even realize they do this and they create unnecessary problems.
Change needles often. They dull after hours of piercing fabric. There's nothing makes your sewing machine happier then to have a fresh, correctly placed needle.
I hope this helps.
Jimmy
Some sewing machines are self oiling some are not, instruction manual should tell,, when a sewing machine breaks needles it very possible that the machine is out of time & only a sewing machine repair shop has the tools to time the machine
SOURCE: Kenmore Sewing Machine 385
check the Bed Drop Lever
Im having the same problem but the lever is not enguaging the bed
SOURCE: Problem with bobbin holder on Kenmore 385.1884180
Take it to your local fabric shop if you don't have any sewing friends who can help you.
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
