SOURCE: Transferring photos
Had exact same problem. Here the solution:
Choose playback, then "Mode" button will bring you Slide show options menu. Navigate to Image/Sound Copy Item.
You'll find options to copy from/to internal memory/flash card there
SOURCE: My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
SOURCE: Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
SOURCE: won't turn on even with new batteries
Clean the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Since the message "The USB device is using too much power. The hub it is connected to has been deactivated" appears before I've even connected the camera to the connector, I suppose it may mean that the connector iss faulty? The camera is functioning normally.
