F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
SOURCE: Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
SOURCE: F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
SOURCE: F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition
Check/Repair
F0 or F1
Failed transistor in control
If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked
If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F3
Open oven temperature sensor circuit
Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
F4
Shorted oven temperature sensor circuit
Same as above; check for melted connector or both leads shorted to ground
F8
Component failure within Electronic Range Control (ERC) effecting temp processing circuits
Replace Electronic Range Control (ERC)
F9
Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch
Check wiring and test operation of switch
