We moved the bike for a party and lost the power cable when we put it back to use again. We bought a new power cable from another supplier but when we plugged it in there is no power to it. We have also now bought another Tunturi power cable but still not turning on. Is there anything simple we can check - have the electrics blown or something come undone? It worked perfectly before.
SOURCE: TUNTURI 620p TREADMILL displays 51, or S1 WHEN
Solution:
press and HOLD the button that says display above it and Reset below it untill you see the normal start up Screen and yoru good to go!
SOURCE: tunturi j440 the console is not lit up when
try turning the switch off then on while plugged in to reset the electronics.
SOURCE: Abrupt stop Tunturi J 660.
I am all set. I located a Tunturi service person in my area. We have an appointment set up. Thanks for following up. I. Hazelhoff
SOURCE: The riser on my Tunturi T20 is stuck on maximum
Phil, I have had the same problem today.
did you solved the problem already?
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Testimonial: "very helpful thanks saved me lots of money "
tunturi repair bike
I have an older model cable that is has circular + and - dial - the tension no longer works. How can I get this repaired SD in Denver
