Mitsubishi WS-65809 65" Rear Projection Television Logo
Posted on Oct 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convergence problem I have an intermittent vertical convergence problem. I have to shut off the TV and turn it back on to get a normal picture again. Need to fix this problem. The TV is a Mitsubishi WS-65809 65in.
Anonymous
Level 3:
  • Master 927 Answers
  • Posted on Nov 03, 2008
Anonymous
Master
Level 3:
Answers
927
Questions
Helped
302311
Points
1655
Good Day;
You have poor connections on your "convergence IC's. Middle board IC's on large silver heat sink. Redo solder before total failure. Good Luck, big IRISH.
Turn TV on.. power light comes on.. sometimes see picture for a few seconds, picture blinks, becomes vertically smaller, then TV shuts off.... sometimes do not see picture at all, before TV shuts off....
the tv is rrar projection i am sorry but these are mento be serviced every 3 years or so but can go faster it is the convergance settings they are adjusted by knobs inside the tv you will need any good tv reapair service it will cost 120 pounds max and it will come with a garuntee but it is worth it as the tv will be like new again this is the problem with rear projection sorry to be the bearer of bad news but i fix these tvs every day...please be sure to make payment and let me know how you get on but please pay no more than 120 pounds
Toshiba projection tv with lines on screen
I have seen a lot of sets where the problem only happens when the set is first turned on---99% of the time one of the two STK-392-110 CONVERGENCE chips this set uses is Flakey--intermittant---The only way to know is replace both of the convergence IC's and see what you have---a bad IC can cause the set to shut down---and sooner or later the set will just shut down and not come on at all.
Let me know if you need more information about this type of repair as I have done hundreds of sets with this type of problem----every one I have ever seen where the convergence was intermittent----replacing the two IC's cured the problem.
REGARDS, SD TECH
Cannot reset vertical convergance
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Toshiba 61H70 Weird Convergence Issue?
They may have gotten some cheap convergence ICs, thats a real possibility. I would recommend switching the two origional STK392-110 with some STK392-150 they will run alot cooler and last alot longer. Just use a good coating of heat sink compound on the back of the ICs. I will post a link where you can get top quality Convergence ICs and they provide free instalation instructions with pictures so you can do the job yourself in under an hour and save quite a bit of money. Heres the link.
http://servicemanuals.vstore.ca/
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Picture turns to lines
sounds like an intermittant connection on the convergence IC'S or the vertical sweep curcuit. I would advise that you seek to have this fixed as soon as possible as tapping on the side can and will cause other problems in the set.. I would also advise that if your not an experienced tech take the set in to a repair shop. Good Luck
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
