I have a Ducane 30400042 LP that I want to change to NG. Maybe we can work up a parts trade. Email me at [email protected]
They should be able to do it from the serial number even if it is NG , Try Calgary BBQ center
SOURCE: how to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
SOURCE: I need to convert my Weber Genesis Silver B grill
I would contact a propane distributor, They should be able to locate the part. I don't know where your at but the one in my area (Central Oregon is Ed Staub and Sons )
SOURCE: I purchased my Weber E-310
Weber doesn't sell a conversion kit. Nor, do they recommend converting their grill's from one gas type to another for safety reasons. Each grill is tested and approved for that specific gas type and changing it would relieve them of any responsibility if something were to go wrong and put it all back on you.
Besides the safety issue, it's more to it than just changing the orifices, as some would lead you to believe. The venturi valves on the burners need to adjusted or is they are adjustable, they would have to be replaced and new LP gas burners installed.
If you have maintained the grill properly and it still looks good, your best solution would be to sell it and put those funds toward a new LP Gas Grill.
I hope this helped you and thanks for choosing FixYa.
