SOURCE: How do I get my Singer sewing machine to sew right
Start right from the beginning, make sure the presser foot is up when you thread the machine, make sure the presser foot is up, top tension should be about 4 or 5, make sure you use a good mercerised thread, make sure the bobbin tension is not too tight, you should only be able to pull the thread through with slight resistence, if it is too tight slacken the large screw on the bobbin case about a quarter of a tutn at a time and test.
SOURCE: thread bunches up on the bottom where the bobbin is
Hello there
if you check the speed settings and make sure that it is not set to a to fast setting this should help also make sure that the bobbin is inserted correctly and fully ok
best regards kim
SOURCE: I have a Singer Sewing Machine 5817C, the thread
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
SOURCE: thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
SOURCE: singer 301a sewing machine does not sew for more
As for the bobbin thread not picking up it could be your hook timing is off. Do you know how to adjust this?
