look in your onwers manuel and it should tell you what your temperature for the freezer should range from.if it was not giving to you when you bought the freezer then it should be behind the pannel down where the compresser is taped to the side.but as you know any thing below 32 degrees is freezing so 5 degrees is pretty cold.i dont under stand about the noise but if you think your freezer is not working right and if it is new then call place where you got it and tell them your concerns and then they should send a technician out
hi brian 20 degrees is too warm for a freezer i think you may have a dirty condensor coil its usualy under the freezer or on the back also check and if it has a fan on the outside make shure its turning let me know what you find and you can e mail me at [email protected]
Good day,
Not really. Domestic refrigerators are designed to operate in an environment where people live.
Most all manufacturers recommend that they not be placed in an area that goes below 55 degrees.
At any temperature below that it starts to degrade.
Cold enough and it will not work at all.
The reason is once the fresh food compartment reaches it's normal temperature of 33-37 degrees, it shuts the whole machine off.
That is by design, on any refrigerator like yours that has only one compressor and cooling fan motor.
As well, there are other issues. In that situation, the machine could well stay off 12 to even 24 hours.
The compressor has an oil sump in it, and the oil becomes very thick. When it finally tries to start, it creates a very stressful situation for the compressor, and could substantialy reduce it's life.
Good day, Yes. Domestic appliances will not work properly below approx 55 degrees. The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower. They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit. The machine is not broken. Moving it inside, is the only solution.
1. Make sure the sealing gasket is making good contact all the way around. It's pretty easy to lose 10 degrees. If it is a magnetic seal on the door gasket, it may not be sealing all the way around.
2. If it is staying that cold, everything is working well enough. Maybe you need a little gas in the compressor. Time for the service guy.
By the way, is your unit speced to be that cold full of supplies? Is the door opened frequently? minus 35 is pretty cold.
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
