Pump runs 10/15 seconds then melts the capacitor! Old motor had a burned out winding and did the same thing. This is a brand new motor from Pentax. I photographed the old wiring as it was going to be a while before the new motor arrived so I am pretty sure it all went back the same. Any ideas? Chris
SOURCE: HELP!!! Help wiring new motor for CKL60-1
Thank You
SOURCE: Start Capacitor wiring diagram needed
When hooking up capacitor on a pump it doesnt really matter which way the wires go. The capacitor is set up in such a way the it supplys power wherever the wires are hooked up. I hope this helps
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
SOURCE: Motor Hums,No Run
Inside the back case on the motor you'll see a white piece with two copper colored arms that have two silver points that almost touch. If these are rusty I've found that the motor won't turn over
. A quick fix is to take some 600+ grit Aluiminum oxide sandpaper and give each of those contact points a brisk sanding to remove any oxidation. This will help the points make a positive contact . Make sure while very obvious that the motor is unplugged first.
SOURCE: PUMP TRIPS BREAKER, BUT SHAFT ROTATES FREELY
Probably not. Take the capacitor off and inspect it for physical damage and if it looks ok take it to an electric motor shop for testing. Assuming it is ok your motor will probably need work or replacement.
