mischa becker Posted on Jan 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instruction manual for archos Gmini x100 model mp3 player
I have no instruction manual
kenneth njonjo
Level 3:
Top Expert:
  • Master 1,575 Answers
  • Posted on Jan 22, 2012
kenneth njonjo
Master
Level 3:
Top Expert:
Answers
1575
Questions
Helped
365439
Points
4558
Download the manual from the link below.
ftp://support.archos.com/XS100/Manuals/EN_GminiXS100_v21.pdf
Hope it helps.
Ken.
  • Terencecanavan
    Terencecanavan Jan 31, 2015
    this link does'nt seem to work
5 Related Answers
A
Anonymous
  • Posted on Jan 31, 2007
SOURCE: archos gmini xs 100
New hard drive. Mine died, too. klick-klack, rrr, klick-klack... end.
Inky
Inky Fingers
  • 705 Answers
  • Posted on Jul 26, 2007
SOURCE: Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Anonymous
  • 250 Answers
  • Posted on May 15, 2008
SOURCE: SanDisk MP3 player MODEL SDMX1 1024R v2
Hello Edwardwf,
It appears that the User's Manual for this particular MP3 player can be downloaded off the Sandisk website at this link: http://www.sandisk.com/Assets/File/tech/docs/dap-user-guide-v2.0.pdf.
Best regards,
Ken
Go Ahead. Use Us.
Anonymous
  • Posted on Jun 25, 2008
SOURCE: archos gmini 402 camcorder
Try turning the unit on with the hard drive disconnected. When I did this (mine had a similar problem) a screen came up and asked me if I wanted to format. I plugged the hard drive back in and reformatted. I had to format twice, but after that it worked fine.
Anonymous
  • Posted on Apr 29, 2009
SOURCE: Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Im trying to download a manual for the archos gmini xs mps player
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
I need a replacement screen for my Archos 402 Gmini
Broke the Back on my Archos Gmini 402 20GB and if anyone has one for sale broken i am willing to buy it from them for the parts as all i need is the rear panel and the screws for the Rear panel.
Archos Gmini 402 camcorder 20GB digtal media player
Hi there this may seem a silly question but the ear phones you are using are a stereo ear phone? or the adaptor to your archos is a stereo one?
2answers
Need directions re: replacing Archos gmini 220 battery
Here is the link to the user manual for your player; http://www.archos.com/support/download/manuals/EN_User_Manual_Gmini200_v121.pdf This link gives the FAQ's for your model; http://www.archos.com/support/customer_support/faq/en/faq_Gmini220.html?country=us&lang=en and says this; "What kind of batteries does my Gmini220 use and how can I replace them? The Archos Jukebox Multimedia uses a factory installed Lithium Ion battery. If the duration of a full charge seems very low, please contact customer service at the following address for US ([email protected]) or the following address for Europe ([email protected]). Please Note: Do not attempt to change the batteries, this could cause damage to your Jukebox and void your warranty." Hope this helps :)
3answers
Archos gmini xs 100
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
