Some minutes after that it turned on, but its stuck and the TOSHIBA logo sceen. None f7.f.8...f12 works and i tried to take off the battery and the AC cable, reconnec it , and it still stuck pls help!! this is the third time it shut down when im using it , the fist 2 it started normally , but now it doesnt
Bonjour,
Le mieux reste d'aller chez le r?parateur pourvoir ce qui ne va pas et agir en cons?quence, mais il est possible que vous soyez oblig? de changer certaines pi?ces alors j'esp?re que ceci vous sera utile:
https://www.distriphone.com/en/5584-Toshiba-Laptop-Parts
SOURCE: Toshiba Satellite M45 Power Problem
Your concern (auto shutting down) with Toshiba
could be caused by excessive power drain by some of the attached
devices such as the WiFi, LAN among others. On the other hand, it could
also indicate that the battery is already weak and constantly requires
charging and at times eats up most of the power from the adapter
leaving nothing for the motherboard to use. In some repairs I have
done, switching off / or removing entirely unneeded devices correct the
problem. In some instances, auto shut down is caused by dirty/clogged
airducts/heatsink of the processor, failing blower/fan and/or poor
ventilation.
Of course, it could not be ruled out that internal problem with the power supply/regulator to have caused the shut down. Alternately, there are some viruses and malwares that could trigger shutdowns.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: My Toshiba Satellite L300D keeps shutting down when I start it up
restart in bios setup
then click to default settings press f10 to save and exit
if problem persists let me know
don't forget to rate
SOURCE: laptop suddenly shut off and will not turn back on
that is hardware problem,, check the processor maybe this over heating only. the cfu fan not working very well just clean the cfu fan....thats all..if over heating problem, cause of ove heating, auto shut off the pc/ laptops.. even the battery full charge.. sometime then hdd comes bad sector cause of auto shut off.. be care full you must wait untill became cold you boar then open again.. thanks
SOURCE: Laptop Toshiba Satellite A200 Model No. PSAF6A-02C01N fail boot
Try removing / swapping / reseating the memory.
Try booting with one stick only, if the top slot doesn't work, try booting the bottom slot. Try both sticks.
Let me know what happens.
Testimonial: "First step in a series to diagnose. On the journey. Useful thanks."
