it seems like your tv remote and your dvd remote are progamed pertty much the same. What you have to do is put some carboard over the eye of the tv so when you hit the remote it will not change the chanels on the tv. I had that problem with my tv box and tv. I would change the chanel on the tv box and the tv would go off. so I had to cover the eye on the tv so it would not change when I used the cabel remote
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
Hi, if you have a "menu" button on the front of the tv go into the menu & "auto-program" the channels, if your set does not have the menu button on the front you will have to call a local tv shop with the model number of your tv and they can order you one, gl, video-tek
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
