SOURCE: I need fax setup for Hp 2140 Fax or a manual
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=3819105&lc=en&cc=us&dlc=en&lang=en&cc=us
SOURCE: My 2140 HP Fax will
you might need to update your driver, which you can do at the following site.
http://www.driversquad.com/driver.php?option=o&prodid=172&cust=HP+USB+download_AD_search.swagbucks.com_1&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
or if all else fails, re-install your software, which you can also do through HP's website
SOURCE: How can I set up
Use the fax setup wizard from the HP toolbox , when it asks if you have an answering machine connected to the fax line say yes. Or setup a distinctive ring from you phone company and set the fax machine to answer double rings only. Use fax setup wizard to do this as well.
