My door is dented and need to replace it - it currently has a black door so I thought I would replace it with a stainless steel version. Does anyone know where a replacement can be found? Is replacing the door difficult?
Instead of replacing the entire door.
Go to http://www.applianceart.com
These guys offer every solution imaginable for refacing your existing dishwashers. They make dishwasher covers in a variety of designs, textures, solid colors and stainless. Check out their website and if you still have questions get in touch with these guys. They are able to walk you through all the available options and keep you from having to replace the entire door.
SOURCE: Doo clips fell out when changing white door panel to stainless steel panel
What door clips ?????
SOURCE: Rust spots on Bosch door panel (1 year old)
I have same problem, low grade stainless will rust, could be the problem
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
SOURCE: How to get rid of rust on the inside of a Stainless steel dishwas
use a scotchbrite pad , or a scouring pad with soapy warm water
SOURCE: can i replace black door with stainless steel on
THERMADOR .COM POST A 4 THUMBS UP FOR THIS INFO THANKS
