SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
SOURCE: I have a behringer 16
I don't believe this board has an "Aux send IN" jack. There are "Aux Send" and Aux Return.
The Aux returns are TRS jacks.
Make sure ALL interconnected equipment are powered from the SAME receptacle or source to avoid damage to equipment.
You might clarify the exact name of the in or out that is not working. I have schematics to help troubleshoot the problem.
SOURCE: where (on-line) can we find download for advanced
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
SOURCE: how do you connect behringer sx2442fx eurodesk
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
SOURCE: My band plugs into the
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Testimonial: "That makes sense. Thanks,"
