When watching sattelite tv on my boxy old standard sony tv i was getting a really annoying bizzing noise when the screen showed bright images or colours especially whites...i put this down to the grand old age of the set so went out and bought a brand new panasonic 50" full HD plasma set and yep you guessed it!...the noise is still there!!!... please help...could this be caused by a faulty cable or something as its affecting two totally different types of set????
I had the same problem when I connected my new At&T cable to the tv card in my PC. I did a little internet research and found out that the problem is called "video buzz". It is where the video signal bleeds into the audio signal. I was connect via coax to the cable box. I was able to fix it on my system by "fine tuning" channel three (my TV card has this capablility). Your system may or may not have this feature. If you are connecting using the A/V input it may be something else.
Thanks for the advice....i'll get right on it.... cheers!
Where is the sound coming from, the television or are you running some kind of audio system? What cablles are you using (eg. HDMI, Component)? I can help you a little more by knowing these things.
If I understand correctly the TV works fine with a DVD through your HK system, but the satellite is the pest. Is it an older receiver? I would just replace the cables from the sat, then get a different receiver from who ever your provider is if the cables dont work. It sounds like the rest of your system is fine.
thanks for getting back to me!.. for both sets the buzzing is coming from the tv... the old set was only connected to the sattelite box via a scart lead and an xbox with standard supplied xbox cable.... the new set is still connected directly to sattelite box via the same scart cable,but the xbox is now connected to a harmon kardon AVR255 which is then connected to the tv via an hdmi cable.... i dont seem to get the buzzing even with bright whites when watching dvd's on the xbox through the AVR it is worst with bright/white pictures when watching sattelite tv.... could a fault or damage to the scart cable be causing this pesky noise?? its driving me a bit nutty considering the expense of trying to upgrade my viewing equipment!... any advice greatly appreciated and anticipated!!!
