Need to know where the anti theft box is located
There are several computer modules involved in your antitheft and security system.
There is the Driver's door module, the right front door module, the right rear door module, the left rear door module, the dash integration unit, the rear integration unit, the instrument panel cluster, the theft deterrent module, the theft deterrent exciter module, the body control module and the powertrain control module. These are all networked together to form the perimeter security and anti-theft system.
Any problems you may be having with this system should be properly diagnosed. Diagnosis of this system must BEGIN with a complete scan of the onboard computer network so that fault codes can be retrieved. and the computer data checked and verified. This is the only way to correctly determine which part of the system is malfunctioning.
Wiring schematics are not designed to give you the location of these components. They only show the wiring connections that are made between them.
What exactly are you trying to fix?
