SOURCE: Measurements for Rice
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
SOURCE: Rice Measurements
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
SOURCE: I lost the cup that came with the rice cooker, and
For Jasmine rice, we use 1.5 C dry unwashed rice to 2.5C cold water.
For Japanese short grain sushi rice which needs washing, we use 2C dry rice, wash and drain it, than add 2.5 C cold water and let soak for 10 minutes, than cook.
For brown rice, we use a 2:1 ratio, water to rice, with 20 minutes soak time.
Hope this helps.
www.areyouagoodperson.com
Testimonial: "Thank you VERY much for getting back to me so quickly, I truly appreciate the information and help!!!"
SOURCE: black and decker flaver scenter rice cooker manuel
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the pdf of the manual for this product
