Power cord shows green light but unit won't power up
If you are encountering power problems with your printer, please
go through the following checklist:
SOURCE: Lexmark 6675. Power won't come on. Power cord
your power supply (black box) is working fine if it has green indicator light on. Make sure you're plugging the power supply all the way in the slot. The power supply can be plugged in an incorrect position so try to double-check that you are plugging it in correctly. Hope this helps.
SOURCE: lexmark x6650 will not identify new cartridges
Please contact Lexmark Technical Support and let them know that you need two replacement cartridges for the two defective ones you have.
Make sure that you purchased factory new Lexmark cartridges, not cartridges that have been refilled and repackaged by a third party company.
Don
SOURCE: I have a Lexmark X6650. Page 1 will not print
I suggest you uninstall the Lexmark software by clicking on the Windows logo Start menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Then, restart pc. If you're connected via the USB cable, unplug the Lexmark printer from your computer. Once pc is on, check if your Vista is running on 32-bit or 64-bit operating system by clicking on the Windows logo Start menu > right click on Computer > Properties. To reinstall, I recommend you use the updated driver from the Lexmark website. For the driver, just click on this link: http://bit.ly/bABYA9 (for 32-bit) or this link: http://bit.ly/bYPUEK (for 64-bit). Download and install the software. Follow the instructions. Hope the helps. Let me know if you still need assistance. Thanks.
SOURCE: i'm trying to scan and it says missing ocr for
The Lexmark OCR scan software is only available on the installation cd that came with your printer. It is not available in the Lexmark.com website as part of the downloadable driver.You may contact Lexmark technical support for additional assistance.
Leading cause of paper
jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
Please visit the Lexmark website to download and install the Lexmark X6650 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
If that doesn't help, try the steps below:
