we've replaced the gas coils, sensor and ignitor and it heats up, but shuts off after about 30 seconds. any thoughts.we've replaced the gas coils, sensor and ignitor and it heats up, but shuts off after about 30 seconds. any thoughts.
Was just about to call the repairman on Monday! This is a relatively new (2 years) dryer. You can occasionally hear the gas kick on every now and then but it seems ike its really just blowing around cold air. Was just about to call the repairman on Monday! This is a relatively new (2 years) dryer. You can occasionally hear the gas kick on every now and then but it seems ike its really just blowing around cold air.
You can't post conmments that contain an email address.
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one. 1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing. The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away. Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off. 2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
try cleaning the moisture sensor bars just inside the door and below the door,with isopropyl alcohol of course after unplugging the unit for fire safety,these 2 chrome colored bars detect the moisture in the clothes and when they are wet they slow or even completely stop the timer,as they dry they let the timer again move,if they get a film on them they will not operate the timer correctly,they work on capacitance
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
