Explain controls
I believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Click here this explains the controls
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
I have just bought the New World electric oven. I have set the clock ok but with a lot of messing about realised the oven doesn't come unless I turn the fan selector knob - thisI was mistaking for the grill. Not sure what these symbols represent can anyone help. Why the so called easy use manual not give diagram alongside the instruction I don't know because it would help.
Thank you Kayla but it didn't relate to the New World electric oven.
