Question about Evenflo Aura Baby Gear
Evenflow carseat cant figure out how to put cover back on
6ya staff
SOURCE:
Anonymous
SOURCE: Can't remove carseat cover
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
Posted on May 30, 2007
Anonymous
  • 6 Answers
SOURCE: Graco snugride infant carseat
first off, make sure of the age of the car seat as there have been safety recalls with this model
here is the web site link to the graco company
http://www.gracobaby.com/customerservice/recall.aspx?categoryID=1
from the home page of www.gracobaby.com you should be able to find the instructions based on the product/serial number on the car seat
Posted on Nov 02, 2007
Anonymous
  • 5 Answers
SOURCE: Carsear Straps
I believe page 3 is what ur looking for. I have done this SOO many times, they get soo dirty soo quick!! Good luck and be safe!!
http://www.elitecarseats.com/assets/product_files/instructions/Eddie-Bauer/EddieBauer_3in1_manual.pdf
Posted on Nov 20, 2007
Anonymous
SOURCE: put back together
2 clips go in top center on back. one clip on each side by handle swivel points. also there is a string you thread underneath th front. Hope that helps
Posted on Dec 04, 2007
Anonymous
SOURCE: Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
Posted on May 30, 2009
Cant figure out how straps go back on carseat since I washed it? its the brown and tan high back with tilt...omgoodness I cant believe I have done this please help!!!!!!
This isn't a product available in the UK so we're unable to assist with your enquiry. Could you let us know what country you're in so we can direct you to the appropriate customer care team?
Aug 04, 2012 | Safety 1st Baby Gear
Need to put car seat cover back together
Hi
Which country are you in / which model Safety 1st carseat do you have?
Dec 05, 2011 | Safety 1st Baby Gear
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
Put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Nov 11, 2008 | Baby Gear
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Evenflow carseat
only do cars sorry
Dec 21, 2007 | Baby Gear
Wheels for an evenflo stroller
check the label on the back of seat and find model and date.
My Evenflo Aura( same as on the picture above) was model #
1782478 and the date of product was 081706. With those numbers go to:
https://plweb.evenflo.com/product_detail.aspx?prodid=11263
Rear whells are for $19.90 and shipping is $9
Sorry for my English, but nobody wants to teach me English in communist Poland twenty years ago :)
Sep 27, 2007 | Evenflo Aura 3s Co Stroller
Car seat straps
ON THE BACK OF YOUR CARSEAT ARE 2 METAL LATCHES ON EACH SIDE. REMOVE ONE BE PUTING THE STRAP THROUGH AND ADJUSTING IT TO YOUR CHILDS FIT.YOU COULD ALSO PUT IT THROUGH A SECONDARY HOLE IF YOUR CARSEAT HAS ONE TO PROPERLY HOLD YOUR CHILD SAFELY.LET ME KNOW IF I WAS ANY HELP...
Jun 03, 2007 | Evenflo Chase Comfort Touch
Baby Gear Logo
Top Evenflo Baby Gear Experts
Ekse
Colin Stickland
Colin Stickland
Matthew Boulden
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
