Posted on Oct 14, 2008
No sound out of centre speaker
There is sound coming out of all speakers, except the centre speaker on my Telefunken 5.1. When i connect centre speaker to front left outlet centre speaker works.
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 14, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
4355
Points
12
Make sure your amp is set to a channel which plays on all speakers (5.1).
If you have the amp set to "Stereo", it is only the frontspeakers and subwoofer which play sound.
How do I make my TV play in Telefunken 5.1 Home Theatre THT-6000HDMIA speakers?
Does the TV and system have either a coaxil or optical sockets? If it does then I would connect them by one of these. That should trigger the sound. However it might work via the HDMI if you have selected the system to pass digital signals via that connection.
1helpful
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Centre speaker
Your center speaker is probably busted since you say you here an odd popping noise from it. You will need to get a new center speaker. It is not your sound card unless the same happens if you buy a new center speaker.
Centre Speaker No Sound
i can think of two things., you may need to do the update on your sound card and computer and make sure you have the correct codec's installed or also you may need to go to the web site of the makers of your logitech speakers and see if they have a common solution for this problem...... i also wonder if you should bypass the sound card and directly connect your speaker system to the out put port on your computer ..... give it a try what can it hurt .... if all else fails maybe there is a faulty wire in the speaker system ....... ahy ?
3 out of 5 speakers not working
my left speaker isn't working. I've check the connections. what can I do?
 Grubhead
Grubhead
SmartAviator
SmartAviator
