SOURCE: I need the wattage on a GE microwave WES1450DMBB
Product Features
try{
var divArr = document.getElementsByTagName('div');
var rpDiv = document.getElementById('tabbed-overview');
var spDiv = document.getElementById('saleprice');
var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv);
if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); }
}catch(e){}1150 WATTS
SOURCE: what is the wattage?
Oddly, the owner's manual doesn't say.
You can contact GE customer service here, or if it's working properly, here's a test that will tell you how much output power it has:
MICROWAVE HEATING POWER
TEST
The
following test will provide a suitably accurate measurement of the
output power of any microwave oven. Variations or errors in performing
this test will produce uncertain results. If the line voltage (from the
electrical outlet) is low, the magnetron output will be correspondingly
low.
Equipment needed:
- Microwave safe
container with 1000 mL (1 Liter) gradation.
- Fahrenheit or
centigrade thermometer
Procedure:
Pour
exactly 1000 mL (1 Liter) of cool tap water into the container. Using
the thermometer, stir the water, then measure and record the
temperature. For accurate results the water should be about 60 degrees
F (20 degrees C).
Place the container on
the center of the
oven cooking shelf (do not leave the thermometer in the container and
remove any metal racks), and heat the water (at full power) for 63
seconds. Use the second hand of a watch, not the oven timer.
After
the heating time is completed, immediately remove the container, stir
the water, re-measure and record the temperature of the heated water.
Subtract the starting
water temperature (step 2) from the ending water temperature (step 3)
to obtain the temperature rise.
To
determine the output power in watts, multiply the total temperature
rise by a factor of 38.75 if you're using a Fahrenheit thermometer or
by 70 if you're using a centigrade thermometer.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: what is the wattage of the ge microwave oven model
This is an 1150 Watt machine.
See the following link for full details:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JES1651SJ
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
Joe.
