Question about RCA Audio Players & Recorders
I a home rca 5 disc cd changer it will read my cds
    Top Expert:
  • RCA Master
  • 76,204 Answers
Hello
Hello
You have an RCA 5 disc CD changer and it reads CDS. Then what is the fault?
Posted on Jan 17, 2012
6ya staff
SOURCE:
Kimi
Kimi
  • 277 Answers
SOURCE: cd player
RCA has had lots of bad laser pickups the past several years. It has to focus before it will spin. Sometimes they will focus and spin but still not read the disc. Unfortunatly that unit is a throw away and no parts or service literature is available from RCA/Thomson. So if cleaning it does not do it, you are probably out of luck. CD lens cleaning discs: Every CD, stereo equipment, department, discount, store - and even sidewalk venders - carries CD lens cleaning discs. Are they of any value? Can they cause damage? I generally don't consider CD lens cleaning discs to be of much value for preventive maintenance since they may just move the crud around. However, for pure non-greasy dust (no tobacco smoke and no cooking grease), they may not hurt and could even do a good enough job to put off a proper cleaning for a while longer. However, it's also possible they will ruin the lens. Consider that the worst thing to do to a precision optical surface is to wipe it with a dry cloth as this is likely to scratch the surface as it rubs the dust over it. To the lens, a speck of dust is like a boulder. Once the lens is scratched, replacement of the entire optical pickup is the only remedy. And, since there are absolutely no sorts of standards for these things, it is possible for a really poorly designed cleaning disc to damage the lens even if the dust itself is non-abrasive. In addition, if the cleaning disc doesn't look like a CD to the optical pickup or disc-in sensor, the lens it may not even spin. So, the drawer closes, the drawer opens, and NOTHING has been accomplished! (But at least no damage will be done.) As if this isn't enough, NEVER put one into a high-X CDROM (DVD player or DVDROM drive). The high speed rotation may cause the cleaning disc and/or player/drive to self destruct. And, don't try a cleaning disc on an automotive CD player that sucks in the disk - it will get stuck.
Posted on Dec 18, 2005
lammy666
SOURCE: sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Posted on Feb 21, 2011
davell
  • 8 Answers
SOURCE: how to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Posted on Mar 01, 2010
Anonymous
SOURCE: stereo won't read cds
You might try running a cleaning CD in it (which cleans the lazer lens). These are available from Wal Mart and many other sources. If a cleaning doesn't get it going, then you may have a lazer that is weakening and might need to be replaced (sorry!). Hope just a good lens cleaning will do the trick.
Posted on Jan 10, 2007
Anonymous
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
RCA 5 disc Changer RS2600 stop reading the cd and and shows "no disc"
The reading eye is most likely dirty and doesn't see the disc clearly. If you can clean it with alcohol on a long QTip, you might get it work again for a while. Dirt & dust are the worst on the opticals. If you can clean it yourself great. Many can't be done without taking the case cover off.
Nov 24, 2012 | Audio Players & Recorders
Won't play recorded cd's
Try a different brand of recordable CD. Some players are sensitive to the color of the disc itself. This is usually only with older players, but I have seen this as a problem in the past.
Dan
Apr 23, 2008 | Nakamichi MF-51 5-Disc CD Changer
CD player just says READ on it
Buy a CD cleaning kit, this will clean the plastic laser lens that is hard to get at, hopefully this will clean any dirt on the lens and bring it back to operational mode.
Mar 04, 2012 | RCA RS2640 CD Shelf System
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Kenwood CD-203 5-Disc CD Changer will not play CDs. It powers up and recognizes a CD within the slot, but it does not read the disc to begin playing.
The laser might be the culpert, be sure its clean by using a swab and a alcohol. If the laser is needed
it could cost approx $75 unless their using a Sony
which might be cheaper!
Apr 17, 2010 | Kenwood CD-203 5-Disc CD Changer
The changer does not detect CDs in it. After
Optical pick up replacement required to rectify this problem
Nov 26, 2009 | Yamaha CDC-697 - CD changer 5-Disc CD...
RCA RTD206/207 five disc changer
i have a rca disk changer model rtd206.my question is what is the remote control code
Sep 14, 2008 | Audio Players & Recorders
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Stereo won't read cds
Jan 09, 2007 | RCA RS2652 Shelf System
572 people viewed this question
Top RCA Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
