DOUBLE VISION AND HORIZONTAL LINES FOR 5 OR 10 MIN.
The cost to repair this problem is about $400-500 depending on local labor rates.With new flat screens as low as $500.00 it doesn't make sense money wise to repair it, this is especially true if the TV is more than 4 years old, flat screens last about 6 years at most before problem s start like burnt out back light bulbs (another $400.00).
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
SOURCE: Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
SOURCE: samsung lcd is after turning on clicking for about 10 min
TV has bad caps on power supply they need to be replace.
SOURCE: Horizontal lines across right side of screen
THIS SEEME LIKE A LOGIC BOARD OR LVDS CABLE COST ABOUT 300 DOLLARS
SOURCE: LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Replace convergence IC's,then check alignment.
Use OEM quality ==I use Panasonic IC's with no call-backs.
T.
