SOURCE: netgear 834
do ur self a favor.... disable the security on ur router.192.168.0.1
user :admin
password: password
you can change ur user name and password to lock out ur neighbor. But you don't need to enable WEP OR WPA.
doing this should take care of ur ipod touch connection.
SOURCE: having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
SOURCE: cant dl anything from winmx!just started using a router
Go to this site to help you forward your router ports for winmx.
http://winmxworld.com/tutorials/routers_info.html
SOURCE: my wnr3500 router will not detect my usb760 modem
Yes you can there are some wireless router now that will work with it, you can check one from Linksys and Belkin also has one..
SOURCE: how to hook up a netgear router to make computer 2
You need to install a wireless card in computer 2.
Then install the wireless driver for this card.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
