Question about Magic Chef MCP13E1ST 1000 Watts Microwave Oven
Microwave oven does not heat anything
The microwave oven does not heat anything up. Periodically it will work. The pizza oven still works. The turntable, light all works fine including the controls. we had the microwave for a about two months we love it and then it stopped working. We want to figure out how to fix it.
  • William Miller
    William Miller May 11, 2010
    It's most likely a loose connection at the magnetron, a bad magnetron, or a bad connection or bad cook relay on the control board.
    Please reply back with your brand and model number so we can help you.
  • Magic Chef Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
l;hkhtguii
Posted on Sep 30, 2010
How to bake pizza in rival micro wave .??how to set it?
Unless the pizza was specifically packaged for microwave use, pizza cooking in a microwave is usually a bad idea. They don't turn out well. Although microwaves are referred to as "ovens", they really don't bake things, they boil them by heating the moisture in the product. Thus, pizza crust will not rise and get crispy unless the pizza was pre-made to be microwave reheated. Those pizzas will give instructions on how to microwave them.
Nov 06, 2015 | Rival Microwave Ovens
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Microwave oven is completely dead
i believe you would have to take the entire microwave caseing off to access the back of the plug
Jul 12, 2012 | KitchenAid KCMS2055SSS Microwave Oven
WE PURCHASED A MAGIC CHEF MICROWAVE-PIZZA OVEN FROM OUR LOCAL MENARDS STORE IN JUNE OF 2010. THE MODEL NUMBER IS MCP13E1ST AND THE SERIAL NUMBER IS DJ10100288. OUR OROBLEM IS THE UNDER SIDE PLASTIC ON THE...
be you cooked something in the micro wave and pizza over at the same time - my wife did the same thing - on she had a towel on top and other things on top to not allow heat to release. hopes this helps
Feb 19, 2011 | Magic Chef Microwave Ovens
It worked fine for pizza two nights ago and does not heat anything. The sensor does not work and food is not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | GE XL1800 1100 Watts Microwave Oven
Emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
Jun 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I warmed up a cup of coffee in our microwave then
This usually means that the magnetron circuit has failed. The magnetron is the part that generates the microwaves to heat the food. Typically the problem is the magnetron itself that has died. The cost of replacement comes close if not more than a new microwave oven. Unless the oven is still under warranty, it not worth fixing.
Feb 14, 2010 | Sharp Microwave Ovens
If you use the microwave and forget to clear the time remaining. Or, if you just leave the food inside, the microwave will start itself in the Pizza mode. I guess it thinks the pizza needs to be reheated??...
You should have a 'clear' button on your oven.
Try to not open the door with the oven running. This causes arcing at the door safety interlock switches and they will fail.
You will know they failed when everything works but there is no "heat". No heat because the oven will think the door is open ... even though you know the door is closed.
Enjoy your new oven ... they are great. I dont know how the Mrs and I would eat if not for the mocrowave!!!
Oct 20, 2009 | Jenn-Air JMC8130DDS Microwave Oven
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
It's probably a defective magnetron.
This should have a one-year full parts and labor warranty, then another several years on the magnetron, typically 9 years.
A typical service call for this might run about $175 for the visit and repair labor, assuming the magnetron is still covered under warranty. Compare that to the cost of buying and installing a comparable oven.
Your owner's manual will tell you how long the magnetron warranty is.
You can save that home visit charge and get a diagnosis for about $25 or so by removing it from the wall and taking it to the nearest GE-authorized servicer.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef MCP13E1ST 1000 Watts Microwave Oven Logo
336 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
