Just got this free printer/scanner/fax from my fionce's mom. she is wanting me to make some wedding invitations for her. but i need to scan the photo she gave me of her and the groom to put on the invitation. i place the photo on scanner screen, press the SCAN button, press OK when it says Scan to Computer, it brings up Downloading Application List for a few minutes then says Cannot Retrieve Application List. what does this mean? and how can i fix this problem??
My printer X5650 will not scan. says downloading application list and then cannot retrieve application list. I can scan manually in control panel. I've removed printer and reboot and reinstalled and still same thing.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.). If that doesn't help, try the steps below:
SOURCE: "Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
SOURCE: i want to print an A6 card as a wedding invitation
Before you print, go to printer settings or print options and select that format
well i searched for solutions to this problem and since i have photoshop CS5 i went to File, Import, WIA Support and chose the location of the printer, pressed start, selected scanner, pressed ok and scan. it shows progress and shows thts its scanning and after it reaches 100% , an error message appears saying "The Device is not ready"
