Pls help us for this problem
SOURCE: Brother MFC 3240C replace black ink
I have replaced all of the cartridge, and it's still saying replace black; or near empty,or no cartridge. I have taken them out put them back in; I have unpluged it and still nothing. What should I do?
SOURCE: red ink nozzle on a brother mfc-240c is clogged
I found an article on how to unclog Brother inkjet nozzles on the InkMagic website. It worked for me.
http://www.inkmagic.com/Articles/Unclog%20nozzles%20on%20your%20Brother%20multifunction%20inkjet%20printer.htm
I'm also using their ink now. I'm a photographer so colour is really important to me. InkMagic ink is as close to the orginal Brother ink as I've found. The MFC-240 cartridges are here:
http://www.inkmagic.com/shopping/shopdisplayproducts.asp?id=1133&cat=Brother+MFC+240c
Hope this helps ... Dale
SOURCE: Over-ride out of ink message Brother MFC-240C
Yes, you can cut a small piece of electrical tape and place it over the window on the inside edge of the cartridge. it has to wrap around the window tightly.
SOURCE: How to check ink level on brother MFC-9440CN?
Run the Brother Control Center. Click Device settings. Click where it says Inklevel.
A simpler way is Start-->All Programs-->Brother--> ...-->Status Monitor.
An icon will lodge itself on the tray (a printer). When icon is clicked on, the inklevels will show.
Hope it helps.
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need:
· Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
