what model and brand hammers we talking about. Email me back and I will see if I can help. I work on them everyday.what model and brand hammers we talking about. Email me back and I will see if I can help. I work on them everyday.
You can't post conmments that contain an email address.
With hammer drills, there are usually 3 positions for operation.
Position 1 - Drill only - drill rotates
Position 2 - Hammer and Drill - Drill rotates and hammers
Position 3 - Hammer only - hammer action
It is important to read the instructions to activate the part to select position 1, 2 or 3.
Sometimes, it is easy to move from position 1 to position 2. Sometimes it is easy to move from position 2 to position 3.
Sometimes it is difficult to move from position 2 to position 3.
When it is difficult to move from position 2 to position 3, you may need to rotate the chuck a little way before turning it to position 3.
The ring of the impact bolt in front inside the locking sleeve where the chisel is driven on can be blocked (also broken part ) but not to see until you remove the parts .
when hammering there is only medium pressure on the unit
you let the unit do the chiselling as any pressure and the unit cannot work as it requires for it to be allowed to rebound a it
The Bosch hammers all use a special grease for the hammering mechanisms. You should be able to buy a small tube similar to the size of a toothpaste tube, from a Bosch dealer or online. The part number is 1615430014. Here is what it looks like.
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
This is normally easy procedure, just press chuck inward and turn clockwise, then retrieve.
This is same way as you will insert/remove your drill from the chuck.
If this method is unsuccessfull, plese rotate knob (close to chuck) anticlockwise till you go to position between chiseling and driling, as this is not lockable position, you need to hold knob in one hand and manipulate chuck with other hand.
This method is described in more detail in manual which comes with hammer-drill.
Hope this solve your problem, this is excellent tool and I always love to use it. Will handle drill up to 20mm in concrete and not even much vibration.
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
piston inside tube has a o-ring on it, these wear over time.. take apart replace piston o ring. Make sure to clean out all grease from inner tube and regrease all these parts when putting back together. should hammer better.
Took mine apart and cannot get the drill/hammer drill/hammer switch to relocate correctly.
I will keep trying now.
