My chef A901 started to smell and leak oil. I started to dismantle it but found that a service manual is needed. Kenwood will not supply this for "Health an safety" reasons. can anyone help...... .
Hi there I am trying to get hold of a copy of the service manual for the A701A mixer.
Would someone be able to send me a copy please....
email is [email protected]
thank you to anyone that can help.
SOURCE: Kenwood chef A901, not working
Found a kit on ebay for 9.99 which fixes the speed cntrol problem on 901 chefs do a search for kenwood motor repair comes with instructions you would need to be ok with a soldering iron
SOURCE: Kenwood Chef model A901 smoke & burning electric smell from motor
there is a kit on ebay for both 701 and 901 kenwoods requires use of soldering iron do a search for Kenwood motor repair it is unlikely to be the motor usually the speed contoller components
SOURCE: What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
