I have a nokia n73 which was given to me by the office. Unfortunately it's in Spanish which I can't understand well enough at the moment.
How do I go about changing the language of the phone to English please.
If you could either give me the words in spanish which i need to find or the pictures of icons or indeed both I'd be grateful.
Share & Enjoy.
Zippy.
1.You take another N73 from that you do your phone than you can cange your phone language spanish to english .
2.OK FIRST open menu and go to tools open, and go to settings open, after you open phone ther will be general ther phone language is there , then you can change. first you see the tools picture and settings picture and ther 1st oen is phone and 1st one is general and there 1st one is phone language
Try to re program ur cp to change ur language....
Sorry do not understand the answer given.
I'm sorry I did not understand the answer given.
Unfortunately the language is Spanish and I can't understand it, so finding the menus you refer to is quite difficult.
I have since found it by chance.
This is what I did for those returning after me.
1. Press the silver button with the two rotating arrows on it, on the left hand side of the key pad. This gets you into the main menu. The default icon highlighted looks like an open envelope.
2. Use the joystick and select the middle icon, 4 from the top. This should be two down from the default icon. The icon to select looks like a folder on its own without any wheels or music notes.
3. This then takes you to the next level. The icon highlighted by default is the screwdriver above a phone icon. This is the settings menu.
4. In the settings menu, select the top menu item. This looks like a mobile phone icon next to a vertical screw driver. This will select the phone menu.
5. In the phone menu, make sure you're on the most left tab, and select the top option. This is the general phone settings menu.
6. Nearly there. The top menu item of the general phone settings is the 'Phone Language' setting. For some reason this was set to 'Automatic'. This being Spain it said this in Spanish and I didn't quite understand what it was referring to.
7. Select the option you require from the list. My options were Automatic, English, Francais, Deutsch, Italiano, and Espanol.
Thanks to all those who looked at my problem for me.
Share & Enjoy.
Zippy.
