We got these phones used from Goodwill (possibly sketchy, I know). There is One main base and three separate mini charging bases - so four cordless phones total. We have let them charge undistubed for two full days. I have used one that works and had a normal conversation on it, but they have decided to not work at all now. (We've only had them a week tops) Sometimes they work, and you can answer calls in and make calls out, but they are consistently dying when you try to pick one up and use it now. As soon as you hit the send button, the screen goes black (as if it were dead) , so we put it in the charging station and it says "charging" and wont go to its normal state for at least an hour, and then it will do the same thing again. Do all of these phones need new batteries? What would cause this? When I tried to register them or whatever I couldnt because they would keep dying and doing the same thing. I know that the phone line shouldnt be an issue because the cord phone we have works fine.
SOURCE: Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
SOURCE: working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
